Rockett Offline
#1 Posted : Tuesday, 6 September 2005 8:01:10 AM(UTC)
Rockett
Help required in identifing Holden 253 turbo 350/400/Chev Bellhousing Engine.
I have in my posession a Blue factory 253 engine with a factory cast chev bellhousing (not re-drilled Holden Trimatic pattern).
It has a ES ###### series engine number what car is it from ????
Cast 23E9 I believe to be the 23 May 1979????
Perhaps a experimental engine?? I don't Know, thus help required.
The 253's I have seen are as follows:
HQ-HZ have QR series engine numbers
Commodore have V series
WB have W
Torana have L
Regards Rockett
#2 Posted : Tuesday, 6 September 2005 4:54:16 PM(UTC)
Hi Rockett.
The 253 block you have is not actually out of a Holden.
The ES prefixed block is out of a Bedford truck.
E = E series Bedford truck (1979 to 1983)
S = lo-compression 253 (it will have originally had a larger than normal dish in the p
HK1837 Online
#3 Posted : Tuesday, 6 September 2005 9:06:40 PM(UTC)
There are heaps more 253 engine prefixes, and Torana are H not L. Examples: 253L, 253H, QR, QS, 11QR, 11QS (possibly), HR, HS (possibly), WR, VR plus others i've long forgotten. ES and ER are new to me. The Chev bolt pattern does not surprise me though. A
mackv8 Offline
#4 Posted : Wednesday, 7 September 2005 6:15:37 AM(UTC)
mackv8
dr terry/byron any ideas on engine no NT10??? is a 308 block pos out of hj has tubo 400 auto on it thanks al
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
HK1837 Online
#5 Posted : Wednesday, 7 September 2005 7:13:51 AM(UTC)
That's a Nasco or GMP&A (GM parts and accessories) factory replacement short motor. Numbers were sequential for all types eg NP1001 for XU-1 followed by NU1002 for GTS350 followed by NR for HQ 253 etc. I used to have NP36**, so yours will most likely be H
mackv8 Offline
#6 Posted : Wednesday, 7 September 2005 8:29:36 AM(UTC)
mackv8
thanks for that it has a hj intake and heads was a bit worried about its legality
#7 Posted : Wednesday, 7 September 2005 6:19:59 PM(UTC)
Hi Dr TERRY / Byron Rich / Mack V8
Thanks for the leads gents I'll be following them up for answers. The block I have has seems genuine and was received with standard size flat top pistons and less water pump, however it MAY have previously had the pis
#8 Posted : Wednesday, 7 September 2005 8:12:21 PM(UTC)
very interesting thread guys i had no idea there was ever a factory produced turbo pattern 253 (even if they weren't for holdens) and the turbo/holden blocks are the same casting + so easy to change...
[IMG]http://i11.photobucket.com/albums/a174/70ute/
Edited by user Wednesday, 7 September 2005 8:15:42 PM(UTC)  | Reason: Not specified
HK1837 Online
#9 Posted : Thursday, 8 September 2005 7:19:02 AM(UTC)
253 pistons are standard flat top for earlier engines, and dome top for later ADR27A engines. That's for the R engine anyway. I'm not sure how big of a dish the S engines had.
#10 Posted : Wednesday, 12 October 2005 12:46:22 AM(UTC)
busteed rockett rippen yarns!!
