treborsenrab Offline
#1 Posted : Friday, 16 September 2005 7:25:28 AM(UTC)
treborsenrab
Hi all. if you viewed my story in "holden garage", you would recall me saying that to save time n money, to rectify my problem with my 186 blowing copious amounts of blue smoke i was going to change my motor for another similarly modded 186. This was the easiest way out cause i had this other motor ready without having to spend,build etc. I'll try to cut along story short here-. i changed my existing inlet manifold to a Cain with a 350 holley to replace the single barrel strommy. after changing it{remember the motor was a chain smoker}, i neglected{forgot} to reconnect the vacuum line from the trimatic vacuum modulator. another point here is i intended to change to a powerglide auto when i swapped the donk. and i only wanted to ensure the holley was worthy of installing on the replacement motor cause it was of unknown quality to me. well....after tuning the holley and running it as well as i could{car is unreg} i noticed the exhaust smoke decreasing slowly and surely to a point where it wasnt noticable at all,even with revving it to 5300,{reckon it has a few more revs but this was no load revving and i dont thrash my cars,often}. yeah, i was totally baffled by this. it was magic,like crossing your fingers and hoping that that 8th pot would magically start firing again!! anyway, after all this i noticed that there was this SPARE hose hanging freely behind the rocker cover.WOT THE?????. im not the sharpest tool, mechanically wise, in the shed i will admit, so i had a look in my SOMETIMES usefull Gregory's manual for placement of this hose.in the manual is states various symptons of problems with a F@@### vacuum modulator,and u guessed it, A SMOKING EXHAUST is one of the signs!, so i changed the modulator for a new one a mate happened to have ,and no more smoke!!!!. now the problem could have been with my strommy all along,but i seriously doubt it.looking on the bright side-all i have to do now is change the TRAUMATIC auto to the powerglide and be happy.Anyone able to blow this theory out of the water? surely this is the cause?! So from what i have experienced here is that this COULD possibly be a saviour from a re-ring job,certainly worth a look first.
be an innovator, not a imitator
#2 Posted : Friday, 16 September 2005 7:30:26 AM(UTC)
treborsenrab
What made me forget where i disconnected the vacuum hose from???,ill blame the canadian club!!,another lesson-dont drink toooo much when playing with cars!
#3 Posted : Friday, 16 September 2005 8:00:41 AM(UTC)
One idea I use and is ideal for the novice or forgetfull is when I do an engine swap I put a strip of masking tape around some of the wires and small hoses with what they are written on them before disconnecting them , this has saved me a few times when w
#4 Posted : Friday, 16 September 2005 8:14:04 AM(UTC)
You have nailed it. Common cause of smoking.
#5 Posted : Friday, 16 September 2005 9:02:35 AM(UTC)
treborsenrab
Cloudy-good advice specially if changing ancillaries that differ,so ive discovered.cheers for the common sense wake up call!
Byron-i take it that the pressure from auto sends fluid through a s#@# modulator into inlet manifold where its burnt or unburnt,
#6 Posted : Saturday, 17 September 2005 9:31:14 AM(UTC)
I use one of those paint pens you get from newsagents to mark the hoses and connections maybe 1 dot, then 2 dots, etc, when not enough room for all the dots go to - or + and so on. also these pens come in handy for marking parts with what they are for. Bu
#7 Posted : Monday, 19 September 2005 9:32:32 AM(UTC)
Rab,
A 350 Holley is not the best carby for a Holden 6....However, about 58 or 59 main jets are usually fine in a 350 for a 186. The Power Valve depends on your cam...match the number to the vacuum you have.
Make sure you have the float level set ri
#8 Posted : Tuesday, 20 September 2005 5:32:22 AM(UTC)
treborsenrab
Dave,thanks very much for the info.
Have followed that procedure, and she sounded great and was fairly responsive,however, i couldnt believe the amount of fuel it used on a private road test run. taken advice ive read on red motor carb choice and found a
#9 Posted : Tuesday, 20 September 2005 6:09:29 AM(UTC)
Hi Rab,
Not at all mate...as I said at the beginning of the post, a 350 Holley is not a good carb for a Holden 6.
One other thing that I forgot was to check your accelerator pump linkage. With the motor off, you should be able to JUST move the throt
#10 Posted : Tuesday, 20 September 2005 8:00:32 AM(UTC)
treborsenrab
Hey Dave, checked my accelerator pump linkage and it is spot on.just not happy with the consumption-i know im not gunna get 40 mpg, but reckon i can do better than the 350 holley's usage.i agree with u on the little 4-barrel holley's.i got the ww-2 and ad
#11 Posted : Thursday, 22 September 2005 9:01:30 AM(UTC)
treborsenrab
Hi Fellas, Bolted the ww2 on today-wouldnt run,tipping fuel into carb top would let it start and promptly die,{thought it was slow in picking up the fuel from the line} discovered no stream of fuel from the squirters-took the fuel pump arm out of the midd
#12 Posted : Friday, 23 September 2005 9:15:48 AM(UTC)
Firstly, I'd be checking for vacuum leaks EVERYWHERE...
Secondly, I'd send me an E-mail (through my profile) and I'll send you the HQ (and maybe HJ if I can find it) WW Strommy setup instructions from my manual. But, before you get all excited about th
Guest (5)
