#1 Posted : Wednesday, 21 September 2005 5:35:20 AM(UTC)
Got a problem with my T5. Grinds into second something shocking, syncro, fair enough but could it damage the main shaft. Iv been skipping 2nd gear and going to 3rd to avoid crunching. Is there main faults with these boxes?
You know what they say...If you cant find 'em...grind'em
Matt
#2 Posted : Sunday, 2 October 2005 1:44:10 PM(UTC)
Matt, I had a VL turbo for years. It was an auto and I converted it to manual for a bit more fun. Ended being a quicker car than when it ran the auto. When I installed the T5 from another VL I had similar problems. Going from neutral to fisrt it would gri
#3 Posted : Sunday, 2 October 2005 1:50:05 PM(UTC)
Who makes adapter kits to put the T5 behind a VL turbo?
From the factory they ran their own (MX7) Nissan 5 speed, which was stronger than the non-turbo version(MF5). It would be a backward step going to a T5.
A lot of people aim to achieve nothing
#4 Posted : Sunday, 2 October 2005 2:33:53 PM(UTC)
Commodorenut, I was always under the impression that a T5 was what they ran.Now I know differently. Positive feedback and information is good. Negative feedback and comments, we can all do with out.
Azza
Taz2 Offline
#5 Posted : Sunday, 2 October 2005 4:27:10 PM(UTC)
Taz2
Aaron...
Commodorenut wasn't having a go at you.
The last line of his reply is his "signature", and is on the bottom of all his posts.
However I can see from reading this thread that it would be quite easy to conclude that the signature could appea
In thrust we trust
#6 Posted : Sunday, 2 October 2005 5:08:08 PM(UTC)
It can also be done by putting "Cheers...." and your name between the body and the witticism...
In Mick's defence, I have NEVER seen him post anything negative.
Cheers...Dave
Edited by user Sunday, 2 October 2005 5:09:09 PM(UTC)  | Reason: Not specified
Taz2 Offline
#7 Posted : Monday, 3 October 2005 3:19:34 AM(UTC)
Taz2
Thought you were supposed to be either up at the Pinnacle, or down in Wonderland gorge at the Grampians Qute.
What happened?
In thrust we trust
#8 Posted : Monday, 3 October 2005 3:34:59 AM(UTC)
Went to the Grampians yesterday. Was a tad disappointed after Tassie though....The Grampians look a lot like the Stirling Ranges down near Albany in WA, even the bush is similar...
Went to the 56/57 Chev Club's triennial meeting in Bendigo today...that
#9 Posted : Monday, 3 October 2005 7:16:42 AM(UTC)
Comments about sig noted, and I have modded it to avoid the same confusion occurring again.
The Nissan box behind the VL 6 is a much nicer box to shift than the T5, and they are much more refined than the T5.
I was actually thinking along the lines
#10 Posted : Monday, 3 October 2005 7:20:08 AM(UTC)
Works well Mick :-))
Cheers...Dave
#11 Posted : Monday, 3 October 2005 8:19:58 PM(UTC)
T5's do have a tendancy to go through synchro's, depending on the stick shifter (ie driver)
DO NOT WRITE BELOW THIS LINE
#12 Posted: : Monday, 3 October 2005 8:25:46 PM(UTC)
#13 Posted : Monday, 3 October 2005 10:38:40 PM(UTC)
T5's were behind the V8's, the Nissan box behind the 6's in the VL's. I think the V6 VN - VS ran a variant of the T5.
Cheers...Dave
#14 Posted : Tuesday, 4 October 2005 6:09:36 AM(UTC)
Spot on Dave.
#15 Posted : Tuesday, 4 October 2005 6:52:33 AM(UTC)
thanx
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audio Master.
#16 Posted : Tuesday, 4 October 2005 8:13:25 AM(UTC)
the MF5 5 speed manual transmission was the base model transmission for SL models, Berlina had this transmission available as an optional extra
Guest (6)
This page was generated in 0.114 seconds.
