#1 Posted : Tuesday, 27 September 2005 8:29:45 PM(UTC)
Hi ,
I have a VX (120 ks) and so far it was going very well. Only last summer and only in very hot days it started to fuel smell inside and it's always when the aircon is on .. happened couple of times and then it stopped in all winter ( nothing at all ) , and just couple of weeks ago when it started being hot and I used the aircon for the first time , the smell came back again for couple of days , weather cooled down and the smell is gone. It didn't fuel smell when I took it to the mechanic and he didn't find any leakage !!!
Have any one gone through such a problem ? I will appreciate your help ?
bluHJ Offline
#2 Posted : Tuesday, 27 September 2005 8:45:55 PM(UTC)
bluHJ
We used to have a fuel smell in some of the V8 Commodores at work on hot days. I'm talking VR etc. When the tank was fullthe fuel vapours would expand enough to fill the charcoal canister and you would smell fuel. Don't know why because the canister
#3 Posted : Wednesday, 28 September 2005 3:20:25 AM(UTC)
Further to Andrew's comments above, do you have the aircon on its recirculation setting? If you do, no fresh air is being drawn into the cabin, so a fuel smell from the boot will works its way into the cabin.
I'd plump for a split/perished breather pip
#4 Posted : Thursday, 29 September 2005 2:23:12 AM(UTC)
I have already checked in the bonnet and things seemed OK . Dave, yes my aircon is on it's recirculation settings .. and I have not checked the boot before so I will check it and let you know . Much appreciated guys.
#5 Posted : Thursday, 29 September 2005 5:34:57 AM(UTC)
check the return lines near the fuel filler.
DO NOT WRITE BELOW THIS LINE
This page was generated in 0.153 seconds.
