#1 Posted : Saturday, 16 December 2006 7:49:52 PM(UTC)
i have a freshly reconditioned AU FALCON cylinder head, it is set up for gas.
the following is a list of work done on the head.
*pressure tested
*acid dipped and sandblasted
*full set of k-line guides
*full set of inlet inserts (gas)
*full set of exhaust inserts (gas)
*new inlet valves
*new exhaust valves
*3 angle valve job
*assembled with new valve stem seals.
*head comes without cam and rocker gear, but can be supplied if needed.
asking $525 for head........or $700 with durapro gasket set and head bolts.
u will pay 550+ for an AU head on gas from an engine shop and thats without new ex valves/inlet valves/inlet inserts, i should know i work in one. this head was done properly to stand up in a straight gas/high kilometer travelling situation.
This page was generated in 0.458 seconds.
