#1 Posted : Tuesday, 4 October 2005 2:32:37 PM(UTC)
Just looking for a few idears on 202 rebuild, i have a standard low compession red motor with webber carbie and elect ignition, it also has a towing cam. It goes ok but the carbie is of a 4.1 ford ,i changed the jets (air and fuel ) from a early 3.1 ford , and would just stutter when you put the foot down, any idears . Would a head of a black/blue 202 be better and would the head be ok with low compression block !!.Is there any other things i can do without getting into big bucks .
#2 Posted : Tuesday, 4 October 2005 4:50:35 PM(UTC)
You dont have a low compression block mate - its the head thats low compression! If you got a blue/black head (the latter being of better flow and durability characteristics), did a bit of work to it (bring up compression to at least 9.5:1) it'd go alrig
#3 Posted : Tuesday, 4 October 2005 5:28:23 PM(UTC)
Just a slight correction there Keith. Dwayne doesn't have a Low Compression head or block.
In the 202's, Holden fitted Low Compression pistons to lower the compression. The heads and blocks are all the same (basically).
There are a rage of compressi
