2 Pages<12
#21 Posted : Saturday, 29 October 2005 5:58:07 AM(UTC)
Well I was told it was a standard Cam by the Mech, He could tell by listening to it. ??. When I put my foot on the brake at idle the engine seems to stumble a bit and then regains idle ( the usual rough idle of course). How ca ya tell if ya a tooth
#22 Posted : Saturday, 29 October 2005 8:22:12 AM(UTC)
Sounds about right Jimbob.
When you spray the water/detergent mix around, you are giving the bits a good soaking, aren't you?
You need the solution to cover and seal any leaks for a couple of seconds so you can pick up that the idle has changed.
#23 Posted : Saturday, 29 October 2005 8:44:42 AM(UTC)
Also may pay to do a compression test both wet and dry. A leaking valve can cause similar problems.
#24 Posted : Saturday, 29 October 2005 6:39:24 PM(UTC)
or a stuck valve...
#25 Posted : Saturday, 29 October 2005 8:08:08 PM(UTC)
thanks guys, The yella terra head is single post adjustable type. The exhaust extractors were found on the engine when bought from wreckers, 2" pipe 1 yr old. I thought I was giving the joints a good watering with the leak check, I heard no drop in
#26 Posted : Saturday, 29 October 2005 11:03:18 PM(UTC)
check for a burnt valve. before it gets too hot, place your hand over the tailpipe. If your hand gets sucked in occasionally you have a burnt valve
2 Pages<12
