G'day, I picked up a M20 four speed box at a swap meet last weekend and I'd like to fit it into my HG sedan, which leaves me with the dilema of either getting my hands on a tonner/ute shifter or fitting buckets.
I'm actually leaning towards fitting bucket seats and perhaps a console. Since HK HT HG buckets are hard to find and expensive if you can, I was wondering what other buckets might fit. I was thinking along the lines of either LC-LJ Torana or HQ-HZ and maybe a HQ-HZ four speed console, but I'm open to sugestions.
Any thoughts on this?
Cheers, Dicko.
Wrecking: 1971 HG Kingswood wagon. Email me for more info. |
"Inteligence is knowing the extent of your opponents stupidity." |
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
The 4-speed and factory shifter does not fit real easily due to an underbody member being in the road. You are much better off fitting a Saginaw or Muncie with a side shifter. Saginaws were standard or optional fitment to HK-HG behind 6cyl (standard in a |
