hi guys, i'm looking for a set of 4 wheel arch moulds for my HK Kingswood sedan (anyone?) but i can't seem to find any without the centre section painted black like this set on ebay- http://cgi.ebay.com.au/H...612QQrdZ1QQcmdZViewItem
My HK has the steel trims all over except for the wheel arches, it is rounded without the sunken centre section and would look silly with the black painted wheel arch moulds. Were there ever specific HK trims without the painted bit, or are all HK/T/G's the same? I'd also like a HK monaro rear boot strip and tail-lights if anyone is prepared to part with some...and a left hand mirror :)
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Left hand mirror post is the same as (or close to) a HQ-WB 1-tonner. The wheel arch moulds are either painted black or red in the middle or not at all.
HK wheel arch moulds you are looking for are either not painted for all models that had them bar th |
i should have said there is only one cross-section. None have the same profile as the kingswood lower mold
70 ute,whats the diff between the hk munro and other hk boot strips? ive got two here but wouldnt know the differences. Rob |
be an innovator, not a imitator |
The Monaro boot strip goes all the way across the bootlid. The premier ones are approx 12 inches long on either side. The kingswood ones are the shortest, about 6 inches either side. If you have a Monaro one I am also interested.
The Monaro one also needs a separate trim piece which fits around the boot lock
i have the short kingswood boot trims + the longer prem ones, but i want the full width monaro strip, last one i saw on ebay (6mths ago) was mint NOS and went for just under $400... p.s. let's not mention over-riders ;) Edited by user Tuesday, 1 November 2005 7:43:31 PM(UTC)
| Reason: Not specified
Sorry mate,mines a premmy strip |
