#1 Posted : Monday, 31 October 2005 5:52:07 AM(UTC)
hey m just wondering what way you turn the mixture screw on a 4mv rochester, in for lean or out for lean
#2 Posted : Monday, 31 October 2005 5:12:10 PM(UTC)
in for lean....................50/50????
its been a few years since i had one.
take it to a good carby performance shop.
will cost you half an hour of labour and will get best results.
VN Calais, V8 Auto, Blown etc etc
#3 Posted : Wednesday, 2 November 2005 5:33:09 PM(UTC)
turn mixture screws right in then wind them back 2and a half turns thats almost a perfect mix then you can work on main idling screw for a notable difference advance dizzy 1 notch 12 degrees
ozchevy Offline
#4 Posted : Friday, 4 November 2005 6:40:44 AM(UTC)
ozchevy
You can easily get 20 more HP out of a Rochester 4bbl. The secrets lie in two areas of concern, #1 The primary jet sizes, and #2 the linkages that open the secondaries. With upping the primary jets to 30 thou and manipulating the secondary linkages to gai
richo2 Offline
#5 Posted : Friday, 4 November 2005 6:27:55 PM(UTC)
richo2
Hi
I have two documents on Rochester carbs one is 11 pages, the other 27. Email me on email_2 at iprimus.com.au if anyone is interested.
#6 Posted : Saturday, 5 November 2005 8:54:29 PM(UTC)
If it's not running right then there is so much more to do than just adjust the idle mixture screws (in for lean, out for rich). The throttle discs must expose only about 40 thou of the vertical transition slot at idle (no more!), the float level must be
