#1 Posted : Tuesday, 15 November 2005 10:38:50 AM(UTC)
Ok I've decided a reconditioned engine may not be the best option. What would anyone consider in terms of a newer model motor for the VL? I'm after a 6 cyl EFI and preferably the simplest to install whilst keeping the budget reasonably low.
#2 Posted : Tuesday, 15 November 2005 5:44:00 PM(UTC)
do you mean you don't want to refit an rb30 to a VL? imho it's already a great motor for an early commodore and seeing as you need to keep the budget small(ish) it would be your best option.
unless you want to fit another higher power jap motor (like rb2
blwnhj Offline
#3 Posted : Tuesday, 15 November 2005 5:49:56 PM(UTC)
blwnhj
yeah uve got that car id stick with the rb30 to.
if you want more stick you could work the motor a bit but it depends on your budget & what you call low.
they are a great motor to turbs if you wanna go down that way!!!
BLWNHJ
BLWNHJ
