#1 Posted : Sunday, 20 November 2005 7:26:27 AM(UTC)
do you need to run an adapter plate when runing a rochester carb on a edelbrock performer holden manifold. Im not running a adaptor plate and the standard gasket is geting sucked into the engine. the manifold originally had an adaptor plate and a 600 holly. any info would be great. where is the best place to get a reco rochester from.
craig
ozchevy Offline
#2 Posted : Monday, 21 November 2005 9:58:11 AM(UTC)
ozchevy
The gasket you need is a Mr Gasket P/N MRG-759
It is 1/4" thick and acts as a heat shield as well as a gasket seal.
#3 Posted : Wednesday, 23 November 2005 7:33:04 AM(UTC)
thanks I will get one and give it a go.
craig
