Fastlane
Holden Forums
Holden General Discussion
LPG fault after fitting electronic ignition??
Hi all,
Have recently fitted a Crane Fireball electronic ignition to my 6 cyl HZ. The car starts better (even cold on gas), however I now have a fault whereby the gas system 'clicks' at the tank end and the lpg tank fuel gauge flashes on the dash at the same time while driving along. This fault only started after the new ignition system was installed, and is only intermittant with no set pattern. Any ideas what the link is? The ignition module is fitted behind the lpg convertor on the inner guard, but I can't see what the link would be?? Any assistance would be appreciated.
Peter
Never late with a 308!! |
202 and three on the tree, can't get more Aussie than that!! |
i got no bright ideas other than did you accidently bump something, or knock of a wire when installing the ignition?
BLWNHJ |
BLWNHJ |
sounds like earth to the sender and guage as that is the only thing that is connected to both safty solenoide (the thing that clicks in the boot )and gauge probably nothing to do with new ignition just a coincedence cheers charles
Thanks guys, will have to check a little closer I guess!
Peter
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
Peter
The LPG conversion (specifically the LPG safety relay) relies upon 'seeing' the engine run by monitoring the coil. It is possible the Crane ignition is creating a 'waveform' (more correctly a pulsetrain) that is outside the parameters of what the |
Thanks Byron, I'll do some investigating.
Peter
If you have no luck investigating the coil, check your power supply lines to each device - don't share the same feed to the ignition system & gas system, as the current drawn by the coil may not leave enough to keep the gas solenoids open.
I've had thi |
Thanks Mick, will need to check on that.
Peter
Fastlane
Holden Forums
