ozjason Offline
#1 Posted : Monday, 21 November 2005 8:31:48 PM(UTC)
ozjason
Hi,
As per the subject, I am looking for:
- HQ blank clock fascia. Not sure if that's the right term, but the blank dash component that looks like a clock (but isn't one) and has Holden written in the middle with the high beam indicator above it. I'm going to cut a large hole in it, so condition doesn't matter. Obviously I still need the clip-in tabs in place...
- Fuel sender to suit HQ ute. Can also be stuffed/inaccurate, as I'm going to have it re-setup anyway.
I know most wreckers will have them, but I figured people here would have them lying around also.
Please reply here or send email via my profile.
Jason.
#2 Posted : Tuesday, 22 November 2005 7:01:20 AM(UTC)
Hi Jason,
I may have a clock blanking facsia...will let you know.
Cheers...Dave
#3 Posted : Wednesday, 23 November 2005 7:47:21 AM(UTC)
Hi Jason,
I had a bit of a dig through my 2 sheds this arvo and found 2 clock/high beam facsias. One is mint and one has had a mechanical temp gauge cut into it (about a 46 or 47 mm hole). The hole is a bit rough, but there is a half moon shaped cover
#4 Posted : Wednesday, 23 November 2005 7:48:22 AM(UTC)
Forgot...I have a stuffed HQ ute fuel sender too...somewhere. Will let you know if I find it.
Cheers...Dave
ozjason Offline
#5 Posted : Wednesday, 23 November 2005 8:47:40 AM(UTC)
ozjason
Hey Dave,
Should have read this before I talked to you! Fuel sender would be cool, mate, would save me having to hit the wreckers...
Thanks,
Jason.
This page was generated in 0.155 seconds.
