#1 Posted : Wednesday, 23 November 2005 4:58:16 AM(UTC)
sorry one more question regarding hose lines, the vacuum advance from the dizzy connects to where??? thanks for the last reply helped heaps.
blwnhj Offline
#2 Posted : Thursday, 24 November 2005 2:37:24 AM(UTC)
blwnhj
i cant give you advice on dizzy but if yyou have any questions regarding these i reccomend you ring a guy named jerry at a business called ignition torque, the guy is an absolute legend and can tell you anything. esp bout dizzys.
he has a drag car which
BLWNHJ
trubluhq Offline
#3 Posted : Thursday, 24 November 2005 4:26:37 AM(UTC)
trubluhq
The vac port on the dizzy goes to teh vac port on the carby. So there is gradual vac advance. Do not put it on the manifold as it will be always on.
BTW - What carb - Quad/Roch, Stromy or Holley ?
Cheers John
#4 Posted : Thursday, 24 November 2005 7:20:10 AM(UTC)
John
That's not quite true on an ADR27A (or similar) vehicle. All of the Xmas tree(s) on the front of the manifold/thermo housing, the electric solenoid controlled by the head temperature and top gear switch all stuff around with the vacuum advance. En
trubluhq Offline
#5 Posted : Thursday, 24 November 2005 7:39:41 AM(UTC)
trubluhq
Byron...yes true enough. It is a SLE too...silly of me.
John
