hi iv been offered to bye a gts dash with all working gauges for my Hq and just woundering is $200 - $250 a good price?
Make sure you get the senders they can be worth a lot.
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
If the fascia is OK snap it up. Try to get the whole under dash harness with it too. You can build one, but they are different to the lesser dashes, unlike HJ on. |
Good idea. they are not that different but you do need to some cutting and soldering and getting connectors otherwise.. The VK 202 injected oil sender is compatible with the GTS oil gauge, don't know about the temp sender
