#1 Posted : Tuesday, 29 November 2005 9:10:19 PM(UTC)
Gday all, great site. I have managed to find an old rat trap style clutch mechanism on ebay, to replace the dodgy frankenstein job fitted by a previous owner on my 253 hj ute with a supra 5 sd conversion. Im expecting it in the post any day now, trouble is Ive never seen one in action and in the pic I have it looks like a set of bloody bagpipes! I can see the cable (for the pedal) and the clutch rod (for the fork) But can anyone tell me where the extra bits actually bolt to? Many thanks for any help given here!
Lucky Phil
#2 Posted : Tuesday, 29 November 2005 10:54:41 PM(UTC)
There should be a stud sticking out of the firewall of a HQ/HJ just towards the centre of the firewall behind/next to the brake booster. One end goes on that stud. If the cab is HX, HZ or WB the stud isn't there or is a different spot. The other bit bolts
#3 Posted : Wednesday, 30 November 2005 4:01:57 AM(UTC)
Thanks Byron thats a great help, I purchased the unit as a "rare as" HQ v8 rat trap so hopefully all will be as promised. The ute is an original Hj manual too, so any difficulties should be confined to adapting the conversion bellhousing to attatch the bi
#4 Posted : Thursday, 1 December 2005 2:51:07 AM(UTC)
it was advertised "rare", not "rare as". direct quotes should be accurate
#5 Posted : Thursday, 1 December 2005 3:05:22 AM(UTC)
LuckyPhil,
you just need to enclose the address of where it is in some img tags
(img)http://www.address.com.au/mypic.jpg(/img)
just replace the round brackets () with square brackets []
If you dont have the pic anywhere up on the net just ema
