hi guys, will a t400 fit into a hk without trans tunnel mods?
cheers, Elton.
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
No. A TH350 will fit exactly where a V8 powerglide does though, meaning HK. The TH400 fouls on the underbody crossmember behind the shifter hole. |
Hello there, I am going to put a th 400 in my HG Panelven..
Yes it will need the tunnel brace thingy cut, but you dont need to pump the tunnel itself. the 350 will go straight in and is fine , but i got the TH400 very cheap and have someone who will |
Bang Bang |
To the letter of the law you really should not touch that body brace as it is integral to the strength of the body, and that part of the floor supports your seats and seatbelts. To do it right and Engineer should be consulted, however lots of these have b |
