can anyone tell me how to work out a build date for a ht monaro and also a part number for a ht left hand rear wheelarch mould cheers
Post your HT's VIN number (skinny plate) here and you'll find out.
7449021 for the LH arch mould (7449020 RH). This is the hardest one to find - it's been obsolte since the 1980's. You'll still buy the other 3 x corners in NOS (try Rare Spares at Home |
Byron, do you know someone who modifies the trims to HK ones?
I bought 3 NOS HT ones from Greg a while back and would eventually like to have them converted to HK ones.
Someone who can weld them and then metal finish them so as to make the repair in
Ask Warren. He will put you onto a fellow named Val in Brisbane.
Val Neil in Brisbane does it, he is reasonably priced from memory.
They are also better than the ones in Vic, which I have also seen, as Val does not leave a fine line in the outside join.
Warren
