#1 Posted : Saturday, 17 December 2005 4:54:49 AM(UTC)
i heard that 302 clevland block is the same as a 351 clevland block but they just have a different crank shaft if some one can tell me if this is true that would be great. thanks
Paul351xb Offline
#2 Posted : Saturday, 17 December 2005 10:16:57 AM(UTC)
Paul351xb
302 has the same block as a 351. A 302 has different crank, rods and heads. Running a 351 crank and rods with 302 heads will really push the compression up and may lead to pinging with these new low octane fuels.
#3 Posted : Sunday, 18 December 2005 4:49:25 AM(UTC)
thanks for that you saved me having to buy a 351 block
XB351 Offline
#4 Posted : Monday, 19 December 2005 6:31:05 AM(UTC)
XB351
I'll confirm that. You can also stroke that engine to as large as 408ci. I personally think 408 is a bit much for the block. 393 is the most I'd go. Do your sums if your rebuilding? Rebuilding to 351 can cost just as much as stroking to 393. I was quoted
