#1 Posted : Saturday, 17 December 2005 6:48:59 AM(UTC)
I am looking for a set of 10" Thermo fans for my UC. Preferably Davies Craig. I can make up a bracket for them and have wiring sorted out, just want the fans!
I live in Townsville QLD
Keith
Death and life are just as pleasant as one another... Its the transition that is painful!
ozjason Offline
#2 Posted : Saturday, 17 December 2005 8:46:21 AM(UTC)
ozjason
Hey Keith,
I put one on the LH when I installed air-con... 10" Davies Craig was only $100 brand new. The rest of your car is new - why skimp on cooling? :-)
I actually bought 2, but then found out I didn't have the room to fit them both... took o
#3 Posted : Saturday, 17 December 2005 9:24:41 AM(UTC)
Why not use Ford EL/AU/BA twin fans with shroud? They seem to go for about $250 complete in Perth and they work exceptionally well...
Cheers...Dave
Edited by user Saturday, 17 December 2005 9:25:17 AM(UTC)  | Reason: Not specified
#4 Posted : Sunday, 18 December 2005 11:38:18 AM(UTC)
Got a pair of Davies Craig I was running on the HQ includes the adjustable switch (strongly recommend you fit a relay to each fan) you can have for $70 the lot plus postage I would guesstimate postage around $20.
They have some blue paint on from overspa
#5 Posted : Monday, 19 December 2005 6:52:30 AM(UTC)
Email sent last night!
#6 Posted : Monday, 19 December 2005 6:54:30 AM(UTC)
I dont know much about the AU thermo setup, can anyone expand on it for me??
Things i would like to know is - How well do they fit to the UC's front??
- Are they pull fans or push fans??
Dylan Offline
#7 Posted : Monday, 19 December 2005 8:08:06 AM(UTC)
Dylan
look on sammy's site, he did a thing about fitting twin thermo's to his LH
#8 Posted : Monday, 19 December 2005 8:17:46 PM(UTC)
Keith, The EF-EL fans are wider but not as tall as the AU-BF fans which are taller & not as wide. The quickest way to tell the difference to the untrained eye is that the EF fans have 8 blades each & the Au fans have 6 blades each.
As a side note v
Edited by user Tuesday, 20 December 2005 7:46:21 PM(UTC)  | Reason: Not specified
#9 Posted : Tuesday, 20 December 2005 7:36:20 AM(UTC)
No need to measure - i think ill stick with davies craig!! Thanks anyways!!
Keith
#10 Posted : Wednesday, 21 December 2005 5:59:19 AM(UTC)
Now that you mention it - AU fans... Do they fit straight on?? I have heard that they only require little modification - can anyone back that up??
#11 Posted : Tuesday, 3 January 2006 9:40:20 AM(UTC)
Seen them fitted to an LH torana.. the AU ones. Like a glove they fit! Just a small trim around the top hose and thats about it.
Almost look factory!
