2 Pages<12
#21 Posted : Monday, 11 June 2007 1:25:05 AM(UTC)
Hi Alex.
The latest (VE) wheels will not fit, the PCD is still 120mm, but the hub centre is smaller & the studs are now a thicker, 14mm (not 12mm).
The 3rd generation (VT-VZ) will fit, the PCD & studs are the same, & the hub centre is larger (in the
Ado Offline
#22 Posted : Tuesday, 12 June 2007 8:51:11 AM(UTC)
Ado
Slightly off subject ,had a hx sedan with hz style wishbones(ball joint mounted in centre) a dash with white needles but european symbols on the guages like the later models.
antoni Offline
#23 Posted : Tuesday, 12 June 2007 10:06:31 AM(UTC)
antoni
Hi we use to redrill HQ dis to ford stud patten when fitting
ford 9" diffs ??????????? May be why studs didnt line up with wheel
ianb Offline
#24 Posted : Tuesday, 12 June 2007 10:45:14 AM(UTC)
ianb
so does this mean that the standard 15 inch mags from a wb statesman will fit onto a hx panelvan no probs?
#25 Posted : Tuesday, 12 June 2007 5:51:52 PM(UTC)
Yes.
ianb Offline
#26 Posted : Wednesday, 13 June 2007 4:03:25 AM(UTC)
ianb
thanks.
2 Pages<12
