#1 Posted : Tuesday, 20 December 2005 9:03:12 PM(UTC)
when i'm driving, there is a lag between gear changes for maybe a second, where the engine free revs, and when it finally goes into gear, there is a clunk, and a the car clicks into gear and shoots forward.
my dad said it may be the solanoid (spelling?). any idea?
lonemonaro Offline
#2 Posted : Thursday, 22 December 2005 2:21:19 AM(UTC)
lonemonaro
[1] Check your transmission fluid level within 10 seconds of turning motor
off hot and check to see if at correct level.
[2] When was the last time was it serviced and transmission fluid replaced.
[3] Check filter in transmission as it may be clog
#3 Posted : Thursday, 22 December 2005 9:20:08 AM(UTC)
What type of auto trans is it. If is a 95LE 4 speed ford trans checK the s5 VPS solanoid. This is a known common fault.They cost about $150. Give me more info and i will see if i can help you. Auto bloke vic.
#4 Posted : Saturday, 24 December 2005 5:14:31 AM(UTC)
i might add that this only happens after the engine as warmed up, and doesn't do it when cold. does this change things?
lonemonaro - the transmission fluid is correct, been recently serviced and fluid replaced and the filter is ok. dunno bout o ring or
lonemonaro Offline
#5 Posted : Saturday, 24 December 2005 1:22:20 PM(UTC)
lonemonaro
Hi,
Might be an idea if you ring up a Auto Transmission place and describe the symptoms that your gearbox is presenting and ask for their advice.
Might be just something simple and thereby save you some money :)
Keep us posted with your resolve :
