#1 Posted : Thursday, 22 December 2005 10:01:37 AM(UTC)
I have an EB II 1993 and at the moment when I turn the ignition there are no
accessories and the engine will not start. When the ignition is in the on
position there are no warning lights.
At any position the smart lock light flashes the standard 1.1 seconds.
My theory is that there is an issue with the ignition system or the actual
mechanism.. At the moment I am attempting the key on for 30 minutes to see
if that provides a solution, however I do not feel confident about this.
I have checked all fuses and relays and they seem to be fine, exempt the
accessory relay as I have not been able to get to it.
I would be grateful for any input to this matter.
#2 Posted : Friday, 23 December 2005 4:26:44 PM(UTC)
WE HAD A SIMILAR FAULT AS BELOW SEE IF THIS HELPS.
WE FOUND THE PROBLEM AFTER LONG DISCUSSIONS WITH FORD.
ALTHOUGH ALL FUSES WERE CHECKED BY ME AND AN AUTO ELECTRITION.
A SIMILAR FAULT WAS FOUND JUST 2 WEEKS AGO AT A FORD WORKSHOP.
FUSE NUMBER
#3 Posted : Monday, 16 January 2006 7:20:44 AM(UTC)
Hmmmm i was going to say fuseable link !
#4 Posted : Monday, 16 January 2006 8:24:31 AM(UTC)
I HAD A SIMILAR PROB BOUT 2 YEARS AGO AND I FINALY TRACED IT TO THE COMPUTER I FOUND THAT THE COMPUTER HAD FAILED I GOT A REPLACEMENT COMPUTER FOR $150 SO IF ALL ELSE FAILS TRY TO FIND A WRECKERS THAT WILL LET YOU BORROW A COMPUTER OR IF U HAVE A MATE WIT
