hello there have just taken delivery of a 78 hz premier wagon i belive it is fairly original I was wondering if anyone can tell me what all these numbers mean Model:hz8wp35 body no: 468477b Trim:193423c paint:56730525 Eng:L31 trans:M41 rraxle:GU4 on seperate plate, holden hz station wagon,11/78,BHZ 18371B on seperate plate GMH LTD 8P35TJH4684772 should be a great project i will let you know how it progresses
How about some pics, you know before and after.
EAP
EAP
EAP
Here are some pics for you potfare! If you want them in another forum (i.e. show'n'shine or holden garage), gimme a yell and i'll chuck them there for you! One of the pics didnt come out right but...
[img]http://memimage.cardomain.net/member_images/3
Thanks: 1 times Was thanked: 636 time(s) in 598 post(s)
It's a factory 308, TH400, 3.08 diff HZ Premier built in the Acacia Ridge plant. Colour is Atlantis blue (1934) with light blue vinyl trim (23C). It looks fully optioned too with what I think was known as a 'country pack' on a HZ Prem which included the |
EAP
They used to have one called a sportsman pack , I have a 77 HX prem with factory 308 T400 and GTS dash with woodgrain it also had GTS rims on it, the previous owner was the second owner and was told by the original owner about an options package called sp
