#1 Posted : Wednesday, 7 February 2007 6:35:23 AM(UTC)
Hi, i know this may sound odd, but has anyone ever measured between the engine mount brackets of an xf while they had there motor out? or any have one out at the moment that they could measure??
After some thought, im going to convert my xf 6 to a bent 8. but it wont be the usual swap.
#2 Posted : Thursday, 8 February 2007 12:06:29 AM(UTC)
I just measured my EB that I am wrecking & the distance between the engine mount holes on the cross member is 40cm.
The EB's engine mounts are exactly the same as the XF's & the engines will drop onto each others mounts so it stands to reason t
#3 Posted : Thursday, 8 February 2007 2:11:39 AM(UTC)
ok thanks for that. will measure up the mounts for my idea and hope it fits.
Wont say what it is till im sure it will work, but it will be "Anything but average"
