landy351 Offline
#1 Posted : Friday, 23 February 2007 3:41:01 AM(UTC)
landy351
Does any body know if an EA-L wagon type fuel tank can be fitted to an XA-C coupe or sedan as I Want to retro fit a 5.0 fuel injected windsor into an XA and just wondering if this would be the easiest way to go or is there an easier solution?
Has anyone seen it done?
Mike
#2 Posted : Friday, 2 March 2007 1:55:58 AM(UTC)
Ok I'll go out on a limb here & tell you that an EA to EL wagon fuel tank is pretty much the same as an XD-XF Wagon tank. In theory an XA-XC wagon tank is probably the same too so if one of those will fit your XA-XC sedan or hardtop then the EA-EL unit s
