Hey guys,
I am going to bin the old 6 cylinder im my XM for a V8 but I am unsure as to what engine/slash gearbox set up would be a bolt in or just a good option in general.
Any ideas, thoughts or suggestions will be great.
289 Windsor would be my first choice then 302 windsor. It all depends if you want a cruiser or something a bit gruntier.
Have to agree with DMAX. Go the Windsor.
I once saw "scmick", a purple XM ute with a turbo'd and injected 250. much less engineering required and plus it's a bit different.
no V8 will "bolt in", because it was never an option on the original car, but it's not as tho it's never been done. A wi |
<<<just me>>> |
Really awesome info guys thanks
Speaking to a guy at dinner last night he basically said the same thing. I think with a 351 im biting off more than I can chew so 302 windsor it is. And the tip for the heads, GOLD.
There was a Ford dealer back in the 60s who used to buy the XM and XP coupes off Ford minus engine and box. He would then drop 289 Windsors into the cars. Over in the US the windsor was an optional fit. They were sold off his lot as new cars with new f
josh, just interested to know why you say scrap the original windsor heads? anything wrong with them? and what power gain would you get with the edelbrocks? just interested cause i'm putting a 302 in my xp with standard heads atm. cheers
I had an XP with a 250/2V and C4 auto and it was very quick and it just bolted started in
Ring an engine builder, then ring another four. They'll all tell you the same thing. No matter how much you spend on your engine, if you don't get the heads right, you're pouring your money down the drain. They don't flow well at all, even when ported. |
<<<just me>>> |
Joined: 2/03/2005(UTC) Views messages in topic : 2,898
