RJR Offline
#1 Posted : Tuesday, 6 March 2007 4:45:03 AM(UTC)
RJR
Hi Guys, I have a slight problem with my front wheels, being 7" wide all round, they are fine on the rear, but on the front they are sitting out a little passed the front guards, I have HR Discs on the front, would like to know if any guys have used that size all round with no problems or would I have to use the 6" wide ones, would appreciate your suggestions thanks
#2 Posted : Tuesday, 6 March 2007 5:31:52 AM(UTC)
hr front end is wider than fj which you probably know, go down to 6 inch , steering will be lighter as well. a lot of early conversions are now using torana rack and pinion steering and brakes, not sure on the width on these setups.
