can anyone tell me what this means? L20 M20 GU4. I don't know what any of it means except that it's possible a factory M20. Any help would be appreciated.
Fcuk Psi
L20 is a hi comp 202. M20 is a wide ratio 4 speed gearbox. GU4 is 3.08:1 diff.
James
You only have to be in front at the end of the race. |
Thanks mate. Is there a website for this sort of thing? I use monaroparts.com for engine numbers but that's it.
Fcuk Psi
The Eric Blair book on Toranas has some of the RPOs in it but I also read a lot of posts about codes here and on the gmh-torana forum and created a list that I refer back to.
James
You only ha |
would i be able to get that list?
Fcuk Psi
Option codes also vary depending upon the model eg L30 is a 307 in HK and 350 in HQ, so it can get confusing. Another few beauties are L34 was to be the 327 in the HK, and it got re-used for the high output 308 in LH. And XU3 or XU4 (forgotten which) is n |
