Could someone please tell me the size & thread of the bolts for all the front panels on a wb ute. I am fixing one up and want to buy a tap to clean out the holes ( a guy at the sunday markets sells em cheap). Also can you buy these bolts with allen heads. Thanks for any help
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
They are metric, but beware as sometimes they can be imperial. Give one of each bolt a try firts by hand before tapping. From memory the metrics are 8mm. Imperial may be 5/16"unf? Both have 1/2" AF heads. The smaller threads on a WB like the ones around t Edited by user Tuesday, 17 April 2007 4:30:35 PM(UTC)
| Reason: Not specified |
where are you wbuteman?
Fcuk Psi
Bundaberg Qld. Will get off my butt one day and sign-up.
The taps you will need are a 8x1.25 from memory and a 6x1.0. A bolt supply place should be able to supply the required bolts but take a sample to be sure to get the right ones.You may have to pay or buy a minumum amount.They dont like selling just 1 bolt
