Fastlane
Holden Forums
Holden General Discussion
4speed behind 308 injected com engine
hi looking at buying a hz with 308 commodore it has a t400 i would like to put aussie 4 speed what am i facing to do this any help appreciated dont know the year for engine yet is fuel injected thanks
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
You just need to buy a complete aussie 4 speed conversion out of a HZ including flywheel, clutch linkages, pedal, tailshaft, gearbox crossmember, reversing switch harness etc. If you can, get one out of a late HZ or WB with a full cable clutch setup (as o |
Fastlane
Holden Forums
