#1 Posted : Wednesday, 2 May 2007 1:45:19 AM(UTC)
hi
am wondering if the driver's side remote mirror which was standard on the HZ Premier (and later Kingswoods) can be used on the passenger door, or is it a different mirror/arm?
was there any HJ-HZ which had a remote passenger side mirror, either standard or an accessory?
cheers frank
#2 Posted : Wednesday, 2 May 2007 2:29:37 AM(UTC)
You cannot use the RH mirror on the LH side, however a fellow here in Qld made a LH mirror neck a few years ago and then you put the head on it, my brother has one on his HJ LS coupe. He stopped doing them as there was no real demand for them, he might do
#3 Posted : Monday, 16 July 2007 3:58:37 AM(UTC)
I certinaly would buy one. (LH mirror neck)
