Hi I have had my hk prem for a year or so and im thinking of converting it to v8. I have done v8 conversions on my valiants but not to a holden. Ideally I am looking for a hk-g v8 donor car but they are getting very hard to find and too expensive. So if i have to do it bit by bit i want to know what I need. obviously i need new wiring, bigger brakes, radiator, new engine mounts but -do i need another engine crossmember?? -what trans crossmember do i need (i want to run a t350 or t400)? are these bolt-in or does the chassis need altering? -will the trans tunnel need modification? -how different are the v8 throttle linkages to the 6 cylinder ones? -can it be converted to a throttle cable? -are the chev engine mounts different to the 253-308 engine mounts? -can i use the same cross member for a chev v8 and holden v8?
All you need is:
New front springs Mount adaptors Engine harness Accellerator linkage Radiator Disc brake system on 6 and 8 the same
Yes mount adaptors are diferent for chev and holden V8
Rear crossmembers for different models and gearboxes
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
A TH350 fits easily but some work is required for the TH400. A TH350 will use a Powerglide gearbox crossmember and HT/G trimatic shifter and aftermarket kickdown cable.
_______________________________________________________ If we all had the same (go |
i have a hg prem if you want a doner car 253 3 speed auto and 10 bolt,1 year old twin exaust system give me a call 0411215615 or44572800 (not reg)
new v8 low king springs as well
Thanks for the responses. that seems easy enough
PREM unfortunately im in adelaide
