#1 Posted : Friday, 4 May 2007 8:45:31 AM(UTC)
Can anyone tell me if you can tell a Yella Terra head by looking at it on the motor?? Its supposed to be on a 202 red thats complete with a mild cam [ and how can you tell that when its sittin on the ground ??]extractors and 350 holley setup on it. I'd get it for next to nothing . I just wanted some of those parts to add to my 186s, I assume the 202 head would go on ok Anyone know how big a cam is till it affects the brake booster? or how you get around the vacuum problem?
Later!
FastEHHolden Offline
#2 Posted : Sunday, 6 May 2007 2:00:57 AM(UTC)
FastEHHolden
You basically cant tell unless you look at the valves and inlet port.
You could remove the rocker cover to see if it has double valve springs.
All bolt on parts like head, extractors, cam will carry over to 186..but if you fit 202 head to 186 use the
#3 Posted : Thursday, 10 May 2007 4:37:50 AM(UTC)
What are the mesurements for the inlet and exhaust valves on a yella terra? do they vary?
