hqGTS2door Offline
#1 Posted : Friday, 11 May 2007 6:10:10 AM(UTC)
hqGTS2door
hey guys just need sum casting dates / part No:'s as im going to the swap meet on sat. (do you read cast dates on inlet and heads same as blocks)
ok heres the list all parts are for a 71 hq
2B inlet manifold
2B air cleaner
4B air cleaner
the exhaust manifold that has the heat pipe to the carby
thanks
trubluhq Offline
#2 Posted : Friday, 11 May 2007 10:22:58 AM(UTC)
trubluhq
Howdee,
From the Oct 73 HQ parts manual
2B inlet manifold 2805483
2B air cleaner 2823654
4B air cleaner 2823655
7436026 RH, 7435825 LH - not sure how u read left or rigth so here is both.
#3 Posted : Friday, 11 May 2007 4:45:19 PM(UTC)
Hi Guys.
In GM-H lingo, the LH & RH of the car is when sitting in the driver's seat. RH is anything on the driver's side of the car. The exhaust manifold with the auto choke heat tube is the RH.
Dr Terry.
#4 Posted : Friday, 11 May 2007 5:38:57 PM(UTC)
Also parts that are "left and right" as a pair/set usually have an odd last digit for the LH side and even for the RH side, often one digit apart ie sequential numbers. There are exceptions, like when HK-HG was released the stub axles followed the "rule"
