If anyone is looking for a 308 trimatic pattern for a HT, date code D230, email me at [email protected]. I might sell the engine as a freshly rebuilt original with warranty or could strip it down to a short motor so that I can use the heads etc. for my date coded build up. It hasn't been run yet....but is just about to be fired up. Bore is 40thou over. Has a mild stage 1 cam and stiffer valve springs but otherwise stock.
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Make sure you have HQ heads for your engine, as HT/G heads are different.
thanks Byron. The engine came out of a HQ before the rebuild, so block/short was HT - top was HQ. Thanks, always grateful of your guidance. Let me know if any HT owners are trying to date code. I got mine sorted, want to give something back via FastLane.
so your wanting to sell the engine? how much are you after? where bouts are you? cheers crocky
Crocky, sorry for the long lead time on reply - been away workin'. I'm sunshine coast QLD. But I am still waiting for my engine as it is coming from Hunter Valley where they've had floods. I'd consider selling the short motor but need to break it down to
