#1 Posted : Thursday, 6 May 2004 12:56:48 AM(UTC)
Hey Guys,
Just wondering if a XE lsd disc brake diff will fit under and work in a my brother's XA sedan??? At the moment its in my XW ute that i'm wrecking, (don't think it was ever registered with it) so it got me thinking!
#2 Posted : Thursday, 6 May 2004 6:49:44 AM(UTC)
the poblem you will have is that your xa is leaf spring and the xe diff is coil sprung,but i guess you know that already.maybe the shocky mounts are different im not sure,but if you put the u-bolts on the housing and bolt it down then grind off the coil
