hg350gts Offline
#1 Posted : Friday, 29 June 2007 1:07:01 AM(UTC)
hg350gts
Hey guys
What do I have to do to make a muncie gearbox fit into a standard HG sag crossmember & shifter? I still want to have the gearstick in the same place.
I read that 1-2 and 3-4 linkages are the same and only reverse is different?
Thanks!!!
Mick.
#2 Posted : Friday, 29 June 2007 4:52:33 AM(UTC)
From what I can see the gearbox mount is in the same place, and the 1st 2nd, 3rd 4th selectors are in roughly the same place, so these could be fine, but the reverse selector rod would have to be shortened. The shifter itself would be fine and the linkage
hg350gts Offline
#3 Posted : Friday, 29 June 2007 5:51:06 AM(UTC)
hg350gts
Thanks Warren
Also it would be interesting to see if the Hurst shifter that came with the box could be used in place of the standard shifter..
