YetAnotherForum.NET Help
#1 Posted : Friday, 6 July 2007 1:53:11 AM(UTC)
Hey i got an EL and when i press the brake the parkers come on and when the head lights are on the cruise control will not work and at night no 1 can see me when braking can some one help me because its scary cheers guy
#2 Posted : Friday, 6 July 2007 6:28:36 AM(UTC)
by the sound of it you have possible a few loose earths more lhan likely it will be in the lights front and probbly rear as well so check all light mounts and wire going to the body
#3 Posted : Friday, 6 July 2007 10:36:20 PM(UTC)
Have you replaced any indicator or brake light bulbs lately? Was there anything that could have started this problem?
It shi ts me to tears when the
#4 Posted : Saturday, 7 July 2007 10:38:39 AM(UTC)
Fords have had wiring problems in the rear for years, when following a Falcon or Fairlane etc always stay back a bit until you see the brake lights working. The problem is bad earths, you have to run new earths from each light parker, stop indicator etc i
This page was generated in 0.154 seconds.
