Looking from the front, in the top left hand corner stamped into the aluminium housing. You don't need to remove the cover, just clean off any gunk and you'll see it. Stamped in same stamps as the 16.7 on the GTS and powered steer car's boxes, and in roug |
Looking from the front, in the top left hand corner stamped into the aluminium housing. You dont need to remove the cover, just clean off any gunk and youll see it. Stamped in same stamps as the 16.7 on the GTS and powered steer cars boxes, and in roughly |
Thanks Byron Rich and Warren Turnbull for your expert advice on the questions that i brought forward to you, i knew that the guru's of monaro's could help me out!!! Thanks alot for that. I can know sleep easier tonight. I have also read that rare spares
Thanks Byron Rich and Warren Turnbull for your expert advice on the questions that i brought forward to you, i knew that the gurus of monaros could help me out!!! Thanks alot for that. I can know sleep easier tonight. I have also read that rare spares wh
They are trying to. I sent them a sample set last year, but they really need a NOS set now to get the correct profile so that they match the guards and quarters correctly.
_______________________________________________________ If we all had the same |
Hi Byron, my steering box is a 16.7 and the number is 23G8, any ideas on a build date? I also have another box 16.7 15M0 that I have picked up in my travels. Cheers
Hi jimmy64
23G8 = 23th July 1968 15M0 = 15th December 1970.
Dr Terry |
Thanks for that, so where all the boxes on the production line that day where hit with that number?
