Hi guys. I am putting a 308 into a rb30 VL. for my mate, and would like any help I can get for the engine mounts. The motor is from a VK so has Commodore mounts and sump. I couldnt find a VL V8 crossmember so this is my plan... I have a VK 6cyl crossmember I am gonna cut the rack mounts off, them cut rack mounts off the VL crossmember and weld onto the VK one. Is there a easier way of modifying to get the 308 into the VL or can you buy mounting adapters Any help would be appreciated thanks
Thanks: 1 times Was thanked: 610 time(s) in 577 post(s)
Just keep looking for a V8 VL one - are they actually different to a VK one? Try Commodore Shop on 0249565582.
Thanks: 1 times Was thanked: 35 time(s) in 33 post(s)
VL ones are different to VK, and the VL K-frame mounts the motor lower than VK as well.
VL-VS V8 front K-frames are the same, so that will widen your search considerably.
Mick _____________________________________________________________ |
thanks guys, I dont normally play on the VL so it a bit new to me. with both crossmembers out they look the same apart from the engine mounts and the rack position... Is this correct? I thought If I used the VK crossmember I'd get the right mounts, then
