Hi All Was just wondering will a crossmember from a sedan/wagon fit a ute/van or are they different Also have a set of sub-rails/chassis from a wagon will they fit under a panel van Cheers Shane
No to both. Get under the ute/van/tonner and compare with a sedan and you'll see why pretty quickly. If you shorten the sedan/wagon/statesman crossmember by about an inch or so each side it'll fit.
______________________________________________________ |
No to both. Get under the ute/van/tonner and compare with a sedan and youll see why pretty quickly. If you shorten the sedan/wagon/statesman crossmember by about an inch or so each side itll fit.
