hi can anyone tell me if u can use a temp swich of a vn v8 etc on 307 chev to run twin thermos fans as i dont trust the one that goes in the radiator hose cherrs
VN V8 had an engine driven fan, and the auxiliries are run by the ECU off the engine temperature senders. The V6 engines have an electric fan but they are also run by the ECU. What you can do though is source a switch off any car that has one and get a s |
cheaper still you can go to Jaycar or RS Components & buy a normally open temp switch for about $5.
I have a 70° one strapped to my lower radiator hose. When the water is coming out of the radiator at 70° or above my fans cut in. theoretically when |
