nick ht Offline
#1 Posted : Tuesday, 21 August 2007 2:01:16 AM(UTC)
nick ht
have stripped car to bare metal and sprayed single pak epoxy primer over it,
is it okay to apply bog directly over it and then apply primer/spray putty over that?
once bog is done and primer/spray putty is applied can i use more bog if i need to fill more lows over them?
will be using acrylic paint for top coat
what type of primer/spray putty should i use?
peter_flane Offline
#2 Posted : Tuesday, 21 August 2007 5:06:15 AM(UTC)
peter_flane
I believe the single pak epoxy should not have filler applied over it.
We do $100+K restorations at work, and to be able to get lifetime guarantee from the paint manufacturer we must use 2 part epoxy on the bare metal chassis and panels. Then the fille
hazzard county Offline
#3 Posted : Tuesday, 21 August 2007 5:25:35 AM(UTC)
hazzard county
gday nick sounds like your doing the body yourself .wow thats a big ask from someone that doesnt know what their doing.panelbeating is an art if you dont know what your doing you could really mess things up thats why crash shops charge big bucks for resto
#4 Posted : Tuesday, 21 August 2007 4:20:49 PM(UTC)
Hazzard is right about it being an art, I do metal finishing at work ,I rework new car panels being doors ,hoods,and decklids for GMH you must have an eye for detail and a good sense of touch to feel minor work like pimples and waves, it takes a lot of tr
kanks Offline
#5 Posted : Wednesday, 22 August 2007 8:05:53 PM(UTC)
kanks
hi nick i like u was unsure if is was up to a full respray.last year i done a full respray on a hg prem i bought for 500$with a little bit of advice from mates and others it turned out not show but very nice.when finished i woz offered very good $ for it
nick ht Offline
#6 Posted : Thursday, 23 August 2007 12:03:08 AM(UTC)
nick ht
okay where can i buy ppg paint in brisbane
