#1 Posted : Tuesday, 28 August 2007 6:09:32 AM(UTC)
Hi guys, Ill be concise as possible, no oil pressure on mechanical gauge, pulled the line from the pump and cranked (no plugs), still nothing, not even a dribble from the pump. No holes in block, no horrible noises, no oil pressure. Happened on overrun at trap speed over 110mph. What are your thoughts? What else can I check? Thanks for your time. Phill
#2 Posted : Tuesday, 28 August 2007 6:14:11 AM(UTC)
so concise I left out the important bit, holden 308 stroked to 355, solid cam etc. No prior indication of crook pressure, 55psi hot, revved to 6000, warmed up good and proper before giving it plenty.Thanks, Phill
Munromad2004 Offline
#3 Posted : Tuesday, 28 August 2007 6:55:33 AM(UTC)
Munromad2004
oil pump drive shaft broken?
Unbolt the oil pump and take a look.
#4 Posted : Tuesday, 28 August 2007 9:02:21 AM(UTC)
i had a similar problem with 253 berlina, never found out what was wrong, it cured itself after a couple of days, but I was not hammering it. (although the problem happened after doing a long hard run)
#5 Posted : Tuesday, 28 August 2007 6:05:48 PM(UTC)
Thanks for the tip, the oil pump is coming off today, i'll check it to blueprint specs, i'll check the drive shaft by turning it against the gear (if that makes sense) if it turns I know i've broken it because the cam is stationary. Is there a way of chec
#6 Posted : Tuesday, 28 August 2007 6:05:48 PM(UTC)
Thanks for the tip, the oil pump is coming off today, ill check it to blueprint specs, ill check the drive shaft by turning it against the gear (if that makes sense) if it turns I know ive broken it because the cam is stationary. Is there a way of checkin
#7 Posted : Tuesday, 28 August 2007 6:36:38 PM(UTC)
#8 Posted : Tuesday, 28 August 2007 8:44:51 PM(UTC)
I pulled the oil pump, turned it with a screwdriver on the bench and oil spewed out everywhere, I guess the pumps fine. I then turned my attention to the driveshaft in the block, it has "free play" of about 90 degrees before it stops (back and forth). Cou
#9 Posted : Tuesday, 28 August 2007 9:54:11 PM(UTC)
Hi Phil.
It sounds like a problem with the gear or its drive pin on the other end of the oil pump drive shaft (near the cam). It could also be the plate that controls the shaft's end float.
You will have to at least remove the front cover & water pu
#10 Posted : Tuesday, 28 August 2007 9:54:11 PM(UTC)
Hi Phil.
It sounds like a problem with the gear or its drive pin on the other end of the oil pump drive shaft (near the cam). It could also be the plate that controls the shafts end float.
You will have to at least remove the front cover & water pum
Sandman Offline
#11 Posted : Wednesday, 29 August 2007 7:37:24 AM(UTC)
Sandman
Some aftermarket cams are incompatable metals with the oil pump drive gears.
A friend of mine just built an 355 and had the same problem. Chewed up a new oil pump drive gear in aprox hour or so running time. Id have to check with him to find out what he
Sandman Offline
#12 Posted : Wednesday, 29 August 2007 7:37:24 AM(UTC)
Sandman
A friend of mine just built an 355 and had the same problem. Chewed up a new oil pump drive gear in aprox hour or so running time. I'd have to check with him to find out what he
#13 Posted : Wednesday, 29 August 2007 8:50:33 AM(UTC)
Originally posted by Dr Terry
quote:<
#14 Posted : Wednesday, 29 August 2007 9:24:32 PM(UTC)
Hi guys, after pulling the engine I took off the timing case. The oil pump drive gear is stripped almost completely. What would have caused such a failure? Could the cam be too hard? Its a come grind solid. How can I prevent this from happening again? The
jabba Offline
#15 Posted : Wednesday, 29 August 2007 9:56:24 PM(UTC)
jabba
Might be worth just checking the mesh of the teeth (i.e. are the cam and pump drive different spacings).
Also, as mentioned previously, the contruction of the oil pump drive vs cam gear could be an issue.
#16 Posted : Wednesday, 29 August 2007 10:07:09 PM(UTC)
#17 Posted : Thursday, 30 August 2007 12:33:15 AM(UTC)
#18 Posted : Thursday, 30 August 2007 7:48:16 AM(UTC)
Think you can buy new gears anyway.
Byron I bought the VK with the 253 motor in it already, thinking it was a 308 but never checked the motor.
Then wondered why it was so gutless and checked it.
The car was only 3 years old and 1 owner so assume it was
Guest (14)
