#1 Posted : Saturday, 15 May 2004 9:33:02 AM(UTC)
Hi folks. I'm now stripping the doors on my ZD fairlane for rust repairs and paint work. I'm stuck on the stainless trims that run along the top of the door next to the window channel. The workshop manual suggests that it should just pop off when i disengage the retaining clips underneath but the best it will do is slide about an inch along the clips. I'm reluctant to force it as i dont want to damage it. Are there any tricks to this procedure? Thanks
#2 Posted : Sunday, 16 May 2004 8:29:05 AM(UTC)
If it is the same as on my XC, And it may not be, there are plastic T clips which pole into rubber grommets. Try to locate them an prise the trim away fron the door with a thin bladed knife or similar. If you are painting the door then you dont really ne
#3 Posted : Sunday, 16 May 2004 10:34:05 AM(UTC)
If all else fails, head down to your local ford wrecker and practice on one of their's :)
