#1 Posted : Friday, 17 September 2004 8:28:32 AM(UTC)
your timing maybe to advanced, this can cause pinging, also using ulp in leaded cars causes pinging because the compression in the leaded motors is higher. when using ulp in these motors its best to use the higher octane fuels as this reduces the pinging aswell as a upper cylinder lubricant.
#2 Posted : Friday, 17 September 2004 8:31:37 AM(UTC)
this was a reply for a post down the column a little
