hi i have a hz tonner 5lt t400 diff says its 2.78 a mechanic told me it is a 3.55 is there a way i can test it to find out what the ratio really is p.s. has 14in wheels thanks in advance
Hi leotard.
An original 5.0 litre TH400 One-Tonner was fitted with a 3.36 from the factory.
You could jack the car up & count wheel turns vs tailshaft turns. Just make sure that the 2 wheels turn together if its not an LSD.
Dr Terry. |
Hi leotard.
You could jack the car up & count wheel turns vs tailshaft turns. Just make sure that the 2 wheels turn together if it's not an LSD.
Dr Terry. |
hi doc to test the ratio is my understanding correct that you turn the tailshaft around counting how many times it turns to the wheels 1 rotation? thanks also the car revs at 3500 or there abouts at 100ks an hr thanks Edited by user Sunday, 23 September 2007 3:56:57 AM(UTC)
| Reason: Not specified
Hey leotard, even i know at those revs, you have at least a 3.36?? i dont know how many turns of tailshaft to wheel turns equals what diff you have,?? would be interested to know?? cheers
ptpro |
more than basketcase than a bear! DOH!!! |
hi fallingbear (interesting name) ive just been out and tested the diff the tailshaft turned about three & a third times to the 1 full rotation of the back wheel leading me to believe the diff is 3.36 you were prety well spot on with your guess thanks
hi fallingbear (interesting name) i've just been out and tested the diff the tailshaft turned about three & a third times to the 1 full rotation of the back wheel leading me to believe the diff is 3.36 you were prety well spot on with your guess thanks
hey leotard, well that answers my question, as to how to check what ratio a diff is? I did not know, what 3.36 and 3.08, etc etc etc meant? now I know, it is the amount of turns of the tail shaft in regard to the wheels? seems obvious now? but I had no |
