2 Pages<12
#21 Posted : Monday, 29 October 2007 4:41:27 AM(UTC)
One of them sure is yours Jon.
#22 Posted : Wednesday, 9 January 2008 11:24:45 PM(UTC)
hi,can you help me i am looking for a wiring loom for my xa its a six and want to go to an 8 xb one would be fine.
home email is [email protected]
Any help would be good.
I will pay for postage no problem
#23 Posted : Thursday, 10 January 2008 1:38:49 AM(UTC)
You shouldn't need to go to an xa loom. if you going to an 8 obvioulsy not keeping the car original.
Only a couple wires need to be changed/extended in order to do the swap.
#24 Posted : Friday, 11 January 2008 12:58:56 AM(UTC)
which wires would i need to change.
help would be appreciated.
I am going to xb loom so i can use the blinker has headlight switch.
and have a gt dash with taco and gauges to hook up.
thanks mate my home email is [email protected]
Paul351xb Offline
#25 Posted : Friday, 11 January 2008 10:06:59 AM(UTC)
Paul351xb
Hope you have an XB indicator stalk then. You might need the XB column too, not sure on that one. Shouldn't be that hard to convert your standard loom over. Any auto electricain should be able to do it. Don't forget you will need the proper oil sender
#26 Posted : Friday, 11 January 2008 7:08:28 PM(UTC)
Yes have the indicator stalk no problem.
i have an xb shell i am taking parts from.
i know about the oil sender unit just trying to figure out the wires.
i have an xa workshop manual so that is helping
i would appreciate anything else you can think of
Paul351xb Offline
#27 Posted : Friday, 11 January 2008 8:58:19 PM(UTC)
Paul351xb
are any of your cars there fairmonts? this might help with a couple of the wire issues.
#28 Posted : Friday, 11 January 2008 9:00:58 PM(UTC)
no mate none are fairmont.
_Craig_ Offline
#29 Posted : Saturday, 12 January 2008 12:00:22 AM(UTC)
_Craig_
So am I correct in assuming you are going from stock 6 cylinder to GT type dash arrangement?
Main ones are of course the oil and voltage, the standard dash still had fuel and temp. Oil shouldn't be hard, it doesn't have to travel far from the sender at
"My comments here must not be taken seriously as I don't own a panel shop and don't have a picture of my car in the members section"
Paul351xb Offline
#30 Posted : Saturday, 12 January 2008 12:43:34 AM(UTC)
Paul351xb
I'm pretty sure the connections for the clock are already in the standard loom. They were with mine. Have to agree in regards to the wiring. If you don't have a GS loom sitting there get a sparky to wire the thing in. Also make sure the tacho is a 7K
#31 Posted : Saturday, 12 January 2008 4:31:22 AM(UTC)
i think taco runs from -on coil. Correct me if im wrong.
Clock not even going to worry about (like you said never runs right anyway).
I have courtesy lights i can use the xa loom has a guide and i have a xa workshop manual hope this will help.
_Craig_ Offline
#32 Posted : Saturday, 12 January 2008 5:24:40 AM(UTC)
_Craig_
Temp probe is in the front of the Cleveland near the heater hose out/in at the water pump. On mine (GT) it is a red wire with white stripe that has a standard female connector on the probe end and the wire runs back into the loom that runs to the coil and
#33 Posted : Monday, 14 January 2008 1:03:00 AM(UTC)
Thank you people.
Your help is much appreciated.
If anyone has more useful info i will be grateful.
2 Pages<12
